Checking if a Scope Device is simulated
I have some simulated Devices in NI MAX for testing purposes.
For DAQmx devices I detect the simulated state with the IsSimulated Property like below:
Imports NationalInstruments.DAQmx
Public Class HardwareLoader
Private Function CheckHardwareStatus() As AICore.EHardwareStatus
  Dim devices As List(Of String)
  Dim device As Device = Nothing
  devices.AddRange(DaqSystem.Local.Devices)
  For Each d As String In _devices
    Dim dev As Device = DaqSystem.Local.LoadDevice(d)
    If dev.IsSimulated Then
      hrdwrStatus = AICore.EHardwareStatus.Simulated
      device = d
      Exit For
   End If
End Function
End Class
I want to do something similar with a Scope device using the NationalInstruments.ModularInstruments Class.
Here parts of my code:
Private _device As DeviceInfo
Private _devices As List(Of DeviceInfo)
Dim modularInstruments As New ModularInstrumentsSystem("NI-Scope")
If _devices Is Nothing AndAlso modularInstruments.DeviceCollection.Count > 0 Then
  _devices = New List(Of DeviceInfo)
  For Each d In modularInstruments.DeviceCollection
    _devices.Add(d)
  Next
  End If
If devices.Count > 0 Then
For Each d In devices
  ' This is the position I need to do the simulated checking
Next
End Class
Unfortunatey there's no 'IsSimulated' Property or 'LoadDevice' Method in the DeviceInfo Class. Is there any way to get this Device information?
Patrick
Message 1 of 1
(1,297 Views)
