WaveForm graph axis caption orientation
Hi, NI team
I have YAxis on WaveForm graph, and this axis has its caption. I can't set the caption text direction to be from left to right...  All I have managed to do is to set it to either from top to bottom or from bottom to top.
Am I missing something or it is not possible to get what I want?
Winforms C# btw
See attached picture.
Regards, Artem.
(4,505 Views)
Hi IDCDeveloper,
I have taken a look into what can be done in Measurement Studio and it seems this is a limitation and you cannot create a caption that has that particular orientation. My suggestion would be to make the caption invisible and try to use a label instead that you can move into the correct location.
It would be a nice feature to have this type of orientation on the caption so I would suggest that you place an entry into the Ideas Exchange section of the forums and your idea may be included in future releases.
I hope this information helps.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
(4,480 Views)
