WPF how to do? AxisCustomDivision gridline ,text?
WINFORM:
var d = new AxisCustomDivision(78, "78");
d.GridLineStyle = LineStyle.Dash;
d.GridVisible = true;
WPF:
 var d=CustomDivision(value)
no text,no gridline,no gridline style?
WPF how to do?
(4,574 Views)
Regarding text, you can use a custom LabelPresenter to control the display of the label. By default, it will just do a basic "to string" of the numeric value.
When we added custom divisions to WPF, we did not implement custom grid lines at the same time. However, you can use the existing grid line renderer to get this functionality. I've attached an example custom grid line renderer implemenation, which supports both distinct styles (as shown in your screenshot), and a simpler uniform style (where you just specify an axis).
~ Paul H
(4,549 Views)
Thank you for your answer. But I don't know how to use it?
phansen 已写:
(4,524 Views)
Thank you for your answer. But I don't know how to use it.
(4,523 Views)
C# code:
SolidColorBrush b = new SolidColorBrush(Color.FromRgb(255, 255, 255));
yAxis1.MajorGridLines = new GridLines();
CustomGridLinesRenderer.ForAxis(yAxis1, b);
WPF XML:
<ni:Graph Grid.Row="0" Grid.Column="0" x:Name="graph" DefaultInteraction="Pan" RenderMode="Hardware" PlotAreaBackground="Black" Interactions="{x:Null}" >
<ni:Graph.Axes>
<ni:AxisDouble Orientation="Horizontal" x:Name="xAxis1" Range="0,4800" Adjuster="None" >
</ni:AxisDouble>
<ni:AxisDouble Orientation="Vertical" Range="0,380" Adjuster="None" Name="yAxis1" >
<ni:AxisDouble.CustomDivisions>
<ni:CustomDivision LabelBrush="#FFC64D4D" Value="78"/>
</ni:AxisDouble.CustomDivisions>
</ni:AxisDouble>
</ni:Graph.Axes>
(4,519 Views)
Accepted by topic author jiewei_li
Ah sorry, I completely overlooked that. To use the renderer, add it to the Children collection of the graph:
    var renderer = CustomGridLinesRenderer.ForAxis(yAxis1, b);
    graph.Children.Add( renderer );
~ Paul H
(4,509 Views)
