WPF graph - show multiple plots with same x axis, each plot has own y axis.
Accepted by Dudiamar
One thing to keep in mind is that these events are synchronous. Thus, you are probably seeing the following:
  1. Graph 1 updates
  2. Range Cursor receives update notification
  3. Graph 2 updates
In which case, looking for data when the range cursor updates will only show the update to graph 1, not graph 2
There are a couple of different ways to solve this:
  • Update the graph without the range cursor before the graph with it
  • Use Dispatcher.BeginInvoke or DispatcherTimer when the range cursor's event is raised so that (3) above happens before you look up the data
Message 11 of 12
(2,101 Views)
I used the Dispatcher.BeginInvoke and it indeed solved the problem.
Thanks!!
Message 12 of 12
(2,031 Views)
