WPF Scatter Plot
I currently have an ObservableCollection<Point[]> which i am binding to the datasource property of a graph. This plots fine, but the points in each point array are joined by a line. Is there a way to turn the line off and just show point markers. If so how? And how might you format the markers?
(5,952 Views)
Accepted by BeckyHayter
By default, the graph uses a LinePlotRenderer to draw data. You can set the Renderer on a plot to use a PointPlotRenderer instead:
    <ni:Plot>
        <ni:Plot.Renderer>
            <ni:PointPlotRenderer Fill="Blue" />
        </ni:Plot.Renderer>
    </ni:Plot>
~ Paul H
(5,935 Views)
