取消
显示结果
搜索替代
您的意思是:
WPF Graph with GraphInteractionPalette hide Buttons
已解决!
转到解答
Hello again,
how can we hide the Buttons from the GraphInteractionPalette?
Like set in the Graph, we just want "ZoomHorizontal, PanHorizontal" (with ZoomToFit)
        <ni:Graph x:Name="niGraph" Grid.Column="0" Grid.Row="1" Grid.ColumnSpan="1" Grid.RowSpan="2"
                       VerticalAlignment="Stretch" HorizontalAlignment="Stretch"
                       DataSource="{Binding Data}" FontWeight="Bold" FontSize="15"
                       local:GraphExtensions.AxesSource="{Binding Axes}" local:GraphExtensions.PlotsSource="{Binding Plots}"
                       niPrimitives:GraphConfiguration.ProcessAllAsynchronousUpdates="False"
                       niPrimitives:GraphConfiguration.UseBackgroundProcessing="True"
                       niPrimitives:GraphConfiguration.UseBackgroundRendering="False"
                       Interactions="ZoomHorizontal, PanHorizontal">
        </ni:Graph>
        <Expander Grid.Column="1" Grid.Row="0" Grid.RowSpan="2" ExpandDirection="Left" IsExpanded="False"
                  VerticalAlignment="Stretch" HorizontalAlignment="Stretch" Header="{Binding}">
            <Expander.HeaderTemplate>
                <DataTemplate>
                    <Grid VerticalAlignment="{Binding VerticalAlignment, RelativeSource={RelativeSource AncestorType=ContentPresenter}, Mode=OneWayToSource}">
                        <Grid.RowDefinitions>
                            <RowDefinition Height="Auto" />
                            <RowDefinition Height="*" />
                        </Grid.RowDefinitions>
                        <ni:GraphInteractionPalette Grid.Row="2" Graph="{Binding ElementName=niGraph}"
                                                    Orientation="Vertical" />
                        <!--<TextBlock Grid.Row="1" Text="T" />-->
                        <TextBlock Grid.Row="0" Text="Legende" HorizontalAlignment="Center">
                            <TextBlock.LayoutTransform>
                                <TransformGroup>
                                    <RotateTransform Angle="-90"/>
                                </TransformGroup>
                            </TextBlock.LayoutTransform>
                        </TextBlock>
                    </Grid>
                </DataTemplate>
            </Expander.HeaderTemplate>
            <Expander.Content>
                <ni:Legend ItemsSource="{Binding ElementName=niGraph, Path=Plots}"/>
            </Expander.Content>
        </Expander>
.NET-Framework 4.7.2 and 4.8
Measurement Studio 2019
Edition: Enterprise
Integration Version: 19.0.4.49154
0 项奖励
1 条消息(共 4 条)
2,858 次查看
解答
接受人 Weber.S
You can assign the InteractionsSource property with the specific interactions you want. In XAML:
<ni:GraphInteractionPalette ...>
    <ni:GraphInteractionPalette.InteractionsSource>
        <x:Array Type="ni:GraphInteraction">
            <x:Static Member="ni:GraphInteraction.PanHorizontal" />
            <x:Static Member="ni:GraphInteraction.ZoomHorizontal" />
            <x:Static Member="ni:GraphInteraction.ZoomToFit" />
        </x:Array>
    </ni:GraphInteractionPalette.InteractionsSource>
</ni:GraphInteractionPalette>
~ Paul H
0 项奖励
2 条消息(共 4 条)
2,825 次查看
解答
接受人 Weber.S
Hello Paul,
thanks for the answer!
But i get an NullReferenceException with your Example.
Stacktrace:
bei System.Xaml.Schema.XamlTypeInvoker.AddToCollection(Object instance, Object item)
bei MS.Internal.Xaml.Runtime.ClrObjectRuntime.Add(Object collection, XamlType collectionType, Object value, XamlType valueXamlType)
<UserControl x:Class="CMO.Common.Controls.NI.Graph.GraphBindable"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation"
             xmlns:niPrimitives="http://schemas.ni.com/controls/2009/xaml/presentation/primitives"
             xmlns:niData="clr-namespace:CMO.Common.Controls.NI.Example"
             xmlns:local="clr-namespace:CMO.Common.Controls.NI.Graph"
             mc:Ignorable="d"
             d:DataContext="{d:DesignInstance {x:Type niData:DataholderGraphWpf}, IsDesignTimeCreatable=True}"
             d:DesignHeight="450" d:DesignWidth="800">
    <Grid>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*" />
            <ColumnDefinition Width="Auto" />
        </Grid.ColumnDefinitions>
        <ni:GraphThumbnail x:Name="niThumb" Grid.Column="0" Grid.Row="0" GraphAdapter="{Binding ElementName=niGraph}" MaxHeight="50" Visibility="Collapsed" />
        </ni:Graph>
        <Button x:Name="cmdShowThumb" Grid.Column="0" Grid.Row="1" Content="Show Thumb" Click="cmdShowThumb_Click"
                HorizontalAlignment="Left" VerticalAlignment="Top" />
                <DataTemplate>
                                                    Orientation="Vertical">
                                </x:Array>
                                <TransformGroup>
                                </TransformGroup>
                        </TextBlock>
                    </Grid>
                </DataTemplate>
            <Expander.Content>
            </Expander.Content>
        </Expander>
        <CheckBox x:Name="chkRefresh" Grid.Row="2" Grid.Column="2" IsChecked="{Binding UseAutomaticRefresh}"
                  ToolTip="Automatische Aktualisierung aktiv?" HorizontalAlignment="Center" />
    </Grid>
</UserControl>
When i set the List in Code-behind and bind it to the Proprty it will work.
                                                    Orientation="Vertical" InteractionsSource="{Binding GraphInteractions, ElementName=userControl}">
                            <!--<ni:GraphInteractionPalette.InteractionsSource>
                                </x:Array>
                            </ni:GraphInteractionPalette.InteractionsSource>-->
    public partial class GraphBindable : UserControl
        public List<GraphInteraction> GraphInteractions { get; set; }
        public GraphBindable()
            this.GraphInteractions = new List<GraphInteraction>();
            this.GraphInteractions.Add(GraphInteraction.PanHorizontal);
            this.GraphInteractions.Add(GraphInteraction.ZoomHorizontal);
            this.GraphInteractions.Add(GraphInteraction.ZoomToFit);
            if (!DesignerProperties.GetIsInDesignMode(this))
                this.DataContext = new DataholderGraphEmpty();
            try
                InitializeComponent();
            catch (Exception ex)
                int i = 0;
            this.niThumb.ViewportRelativeHorizontalRangeChanging += NiThumb_ViewportRelativeHorizontalRangeChanging;
Where comes the null-reference from?
And sorry for the late responce, i am on Holiday and just frequently check my business-mails.
Thanks!
3 条消息(共 4 条)
2,805 次查看
Strange: using that XAML in either the main window or the user control works fine for me (I never see a null exception). Based on the exception message, I agree the XAML array is somehow the cause.
That said, the XAML-only approach was just to minimize the size of the example. Your workaround using a binding is more common, and very appropriate in this situation.
~ Paul H
4 条消息(共 4 条)
2,798 次查看
