Vision - Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Hi all!
I'm trying to develop an application in Visual Studio .NET 2005 with NI Vision but when I try to use the function LearnCalibrationGrid, I get a RunTime error as specified in the subject (Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))).
I've been reviewing all the parameters and everything seems to be ok, so I don't understand the origin of this error!
Can anyone help me out with this?
Txs.
Nuno
(7,975 Views)
Hi
Could you send me your code please?
I want to check if i can reproduce the problem in my machine.
Do you have this exception each time you launch your code?
Kamal
NI France
(7,956 Views)
Good morning!
The code I was implementing is something like this:
CalibrationGridOptions.GridDescriptor.Unit = CWIMAQCalibrationUnits.cwimaqCalUnitMillimeter;
CalibrationGridOptions.GridDescriptor.XStep = float.Parse(txtSpacing.Text);
CalibrationGridOptions.GridDescriptor.YStep = float.Parse(txtSpacing.Text);
CalibrationGridOptions.ThresholdRange.Initialize(0, float.Parse(txtThreshold.Text));
LearnCalibrationOptions.CalibrationMethod = CWIMAQCalibrationMethods.cwimaqNonlinearCalibration;
LearnCalibrationOptions.CorrectionRegionMode = CWIMAQCorrectionRegionModes.cwimaqFullImage;
LearnCalibrationOptions.CorrectionScalingMode = CWIMAQCorrectionScalingModes.cwimaqScaleToPreserveArea;
LearnCalibrationOptions.LearnCorrectionTable = true;
LearnCalibrationOptions.LearnErrorMap = false;
CWIMAQRegions regions = new CWIMAQRegions();
regions.AddRectangle(Vision.MakeRectangle(0, 0, CalibrationTemplate.Width, CalibrationTemplate.Height));
NationalInstruments.CWIMAQControls.
CWIMAQVision testtt = new CWIMAQVision();
CWIMAQImage testimage = new CWIMAQImage();
testimage.SetSize(640, 480);
testimage.ArrayToImage(byBuffer);
testtt.LearnCalibrationGrid(testimage, CalibrationGridOptions, LearnCalibrationOptions,
ref QualityScore, regions);
Where bybuffer is a byte[640,480] that holds the data of the image. I don't know if I'm missing any initialization that can be needed, but I've looked to the documentation and I can't find anything about it!
I'm using Visual Studio .NET 2005, Framework 2.0, Windows XP and the NI Vision 8.2.
Thanks for your support!
Nuno Mendonça
(7,935 Views)
Hi Nuno,
First of all keep in mind that you have to specify all the following attributes in a calibration:
* Specify grid calibration
* Specify dot image: It is the image acquired in your condition replaced  by the dot image
* Specify what kind of calibration it is (non linear distorsion in your case)
* Specify the treshold level to separate the dots of the grid from the background of the image
* Specify the space between the dots (dx and dy and yhe units)
* You also have to specify a coordinate system.
I am almost sure that you don't have use all this attributes. So send your project i will check!
Is the error appears during the compilation or when you are executing your code? Do you have tested a simple calibration instead?
Kamal
NI France
(7,908 Views)
