Using peakDetect on an input signal from a daq card
I am reading in a generated sine wave and it seems to be working correctly, but I need to be able to find the peak as I am going to be comparing the voltage and current of an AC circuit when I get the basics working. The problem I'm having is that the peak detect wont work on the graph as I believe it does not just contain exclusively integer values, is there a way of just taking integer values from the graph and using the peak detect function.
The following is the code I have so far, the daq task was all completed using the wizard so it is just standard.
Public Class Form1
    Dim amplitudePeak() As Double
    Dim waveform() As Double
    Dim locationPeak() As Double
    Dim secondDerivativePeak As Double
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Try
            Dim acquiredData() As NationalInstruments.AnalogWaveform(Of Double) = DaqTaskComponent1.Read
            ACsignal.PlotWaveforms(acquiredData)
        Catch ex As NationalInstruments.DAQmx.DaqException
            MessageBox.Show(ex.Message, "DAQ Error", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        End Try
    End Sub
    Private Sub DaqTaskComponent1_Error(sender As Object, e As DAQmx.ComponentModel.ErrorEventArgs) Handles DaqTaskComponent1.Error
        'TODO: Handle DAQ errors.
        Dim message As String = e.Exception.Message
        MessageBox.Show(message, "DAQ Error", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        DaqTaskComponent1.StopTask()
    End Sub
    Private Sub DetectionOfPeaks()
        Dim peakPolarity As NationalInstruments.Analysis.Monitoring.PeakPolarity = Analysis.Monitoring.PeakPolarity.Peaks
        Dim peakDetect As NationalInstruments.Analysis.Monitoring.PeakDetector = New NationalInstruments.Analysis.Monitoring.PeakDetector
        ACsignal = waveform
        'Detection of Peaks
        peakDetect.Detect(waveform, True, amplitudePeak, locationPeak, secondDerivativePeak)
This is the main error I am experiencing
Error 3 Value of type '1-dimensional array of Double' cannot be converted to 'NationalInstruments.UI.WindowsForms.WaveformGraph'.
Any help is greatly appreciated!
(4,242 Views)
Hello gary,
Is it possible to send me the command that you are using when you are calling DetectionOfPeaks?
Is it also possible to send a screenshot of the error message?
Jonas
Applications Engineer UK&IRE
(4,205 Views)
Hi Jonas,
I managed to solve the problem I was having with the peak detect I used the following code to get the peak and number of peaks
            Dim a() As Double
            a = acquiredData(0).GetScaledData
 initialthreshold = -2.4 'Setting the initial threshold'
            initialwidth = 10 'Setting the initial width'
            'To detect the associated peaks withing the wave'
            peakdetect.Reset(initialthreshold, initialwidth, 0)
            peakdetect.Detect(a, True, amplitudePeak, locationPeak, secondDerivativePeak)
Now the graph is plotting fine, there is one more problem I am having, is there anyway that with the given "a" max amplitude along the Y axis, I am able to get a value for the corresponding X axis value which in this case would be a time value. As I am inputting 2 sine waves and I need to find the difference on the X axis between the 2 peaks. This is what I have so far,
            Dim a() As Double
            Dim b() As Double
            b = acquiredData(1).GetScaledData
            peakdetect.Detect(b, True, amplitudePeak, locationPeak, secondDerivativePeak)
            'To display the number of peaks found in signal
            numOfPeaksFound = amplitudePeak.Length
            peaksFoundNumericEdit.Text = numOfPeaksFound
            peakAmplitudeNumericEdita.Value = a.Max
            peakAmplitudeNumericEditb.Value = b.Max
Thank you for the help it is greatly appreciated!
Gary
(4,201 Views)
