Using AxisMode.AutoScaleExact
I am creating a Scattergraph and have formatted the x axes to use AutoScaleExact.  Then I set the label formatting. However the first and last X axis values are not formatted.  Only the between values.  When I use AutoScaleLoose it works fine, but I do not want the space between the end of my X values and the graph.
Here is some pseudo code
NationalInstruments.UI.WindowsForms.ScatterGraph gph;
gph.XAxes[ 0 ].MajorDivisions.LabelFormat = new NationalInstruments.UI.FormatString( NationalInstruments.UI.FormatStringMode.Engineering, "S2" ) );
Below is my actual XAxis Data.  The Red numbers are not formatting on the ScatterPlot, but everything between is displayed as   -xx.xx.
-41.0035607596107
-40.0015295290651
-38.996749346679
-37.9992674220449
-36.998142577727
-35.9992276384369
-34.998859261285
-34.001078962965
-32.9919809363304
-32.0111341502177
-30.9959783684086
-29.9953824876186
-29.000555832272
-27.9974909602027
-27.0112169298094
-26.0073849837914
-25.0025153803095
-24.0047350819895
-23.0085242380708
-22.0053854795465
-21.0065053894608
-20.0003115941921
-18.9981814076384
-17.998379656487
-17.0108602825659
-16.0019098545771
-15.0037920905902
-14.0060117922702
-13.0000685535524
-11.9969297950281
-11.0001712701157
-10.0021591197495
-9.00332538531791
 So my XAxes is as such.
   -41.0035607596107          -30                -20           -9.00332538531791
And I want
   -41.00          -30.00                -20.00           -9.00
Thanks for any advice,
The Only Easy Day Was Yesterday.
(3,753 Views)
Hello
What version of Measurement Studio are you using? I was unable to reproduce this in version 8.0.1.
Bilal Durrani
NI
(3,735 Views)
Thanks for looking into it.
I am referrencing Measurement Studio .NET User Interface Library. The NationalInstruments.UI.   It is version 8.0.11.236.
Matt
(3,703 Views)
