Unable to find module dependency with signature 'Microsoft_VC110_CRT_x86.F9D0B380_EB85_31D4_96AC_C6CB40086A55'
Hi there,
I get the above error from the Visual Studio installer caused by the following merge modules, having a dependency to the Microsoft_VC110_CRT_X86 merge module:
    nimodularinstrumentscommon.2012.msm
    nimodularinstrumentssystem.2012.msm
    ninetscope.fx45.msm
The Microsoft_VC110_CRT_X86 merge module is installed on the system, but it has the wrong signature.
Where can I get the merge module with the right signature? Or is there an other solution?
Regards from Berlin
Chris
Environment:
    Windows 7 Professional
    Visual Studio Professional 2013 Update 5
    Measurement Studio 2015 Professional
    Visual Studio Installer Extension
References:
    .NET Framework 4.5
    Ivi.Driver
    Ivi.Visa
    NationalInstruments.Analysis.Professional
    NationalInstruments.Common
    NationalInstruments.DAQmx
    NationalInstruments.ModularInstruments.Common
    NationalInstruments.ModularInstruments.ModularInstrumentsSystem
    NationalInstruments.ModularInstruments.NIScope.Fx45
    NationalInstruments.UI
    NationalInstruments.UI.WindowsForms
    NationalInstruments.Visa
(3,957 Views)
did you see Measurment Studio .NET Merge Modules?
Best,
anna
Anna Vogl
Certified LabVIEW Developer
(3,891 Views)
Hey anna,
thank you for your answer.
Yes, I saw this site.
In my case, the listed merge modules are proper installed on the system, I just have a signature mismatch.
What I need is the merge module with the right signature.
So, why is this site useful for me?
Regards
Chris
(3,879 Views)
Hi Chris,
this was just for general overview. I have now looked into this issue further and it is a known problem with NI. There is already a corrective action request filed for this but I don't know when or if it will be fixed.
Recommendation is to use the Installer Builder instead.
Alternativley you can create your signature yourself. There are instruction for that on the microsoft homepage. But it is not that easy to implement.
Best,
Anna
Anna Vogl
(3,871 Views)
Hi Anna,
Thank you for your recommendation. The installer project is a big project, it's not an option to use the NI Installer Builder instead, unfortunately.
Is it possible to get the merge modules (x86, x64) with the correct signature from your support (download or e-mail)? That would be nice.
Do you have a direct link to the site about creating a signature on the microsoft homepage?
Regards
Chris
(3,869 Views)
Hi Chris,
unfortunately I can't provide the modules with the right signature.
This is a link to a tool called Orca. With this tool you can edit merge modules.
Best,
Anna
Anna Vogl
(3,860 Views)
