If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
05-21-2015 08:39 AM - edited 05-21-2015 08:51 AM
I have a Visual Studio 2013 c# project in which I want to use the NationalInstruments.Tdms namespace to write data to a file.
I was unable to add the assembly immediately through the Reference Manager dilaog because after searching the NationalInstruments.Tdms assembly was not listed.
So, I did a search for NationalInstruments.Tdms.dll on my system and found:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\NationalInstruments.Tdms\v4.0_13.0.45.242__4febd62461bf11a4\NationalInstruments.Tdms.dll
...so I added that and I was able to start writing code against that namespace. However, when I came to running it I was told:
A first chance exception of type 'System.ComponentModel.LicenseException' occurred in NationalInstruments.Common.dll Additional information: NationalInstruments.Tdms.TdmsLicenser is unlicensed.
So, I added a line to my project's licenses.licx file so that it looked like this:
NationalInstruments.Tdms.TdmsLicenser, NationalInstruments.Tdms, Version=13.0.45.242, Culture=neutral, PublicKeyToken=4febd62461bf11a4
However, now when I try and run my project it doesn't even start. I get the following warning dialog:
Can anyone give me any pointers as to why this is not working, please?
05-21-2015 09:56 AM
Isn't the TDMS .NET assembly a part of Measurement Studio 2013?
If so, Measurement Studio 2013 does not support Visual Studio 2013. http://www.ni.com/mstudio/whatsnew/
05-22-2015 04:32 AM
So far everything else I have used from Measurement Studio (device control, task definition etc.) works fine, it just seems to be that the VS integration doesn't work.
So I'm hoping there is a workaround to enable me to make use of the included asseblies even if I have to set everything up manually.
05-24-2015 12:51 PM
