 jyysns
			jyysns
			09-28-2019 06:47 AM
I have installed Visual Studio 2015 on my computer.The following error occurred when I installed Measurement Studio 2019.It said:Packages with compatible versions and architectures could not be found.
 Johann78
			Johann78
			10-02-2019 02:58 AM
I've the same problem with Package Manager 19.5.0.
I've started a service request.
I'll let you know if I get a solution.
Johann
 Johann78
			Johann78
			10-02-2019 03:25 AM
It seems to be a problem of NI Package Manager 19.5.
I've uninstalled it and installed the older 19.0 Manager and it works fine.
Johann
 Vasilich2004
			Vasilich2004
			10-03-2019 05:24 PM
How were you able to use NI Package Manager 19.0?
I uninstalled NI Package Manager 19.5 and install NI Package Manager 19.0. When I tried to install Measurement Studio NI Package Manager 19.0 pushes to install NI Package Manager 19.5 without any option.
 Johann78
			Johann78
			10-07-2019 12:40 AM
I ran Package Manager 19.0 and select NI Measurement Studio 2019 ...
Maybe you've executed the Measurement Studio online installer first?
Hans
 AlexisMesa
			AlexisMesa
			07-24-2020 10:17 AM
I had very similar issue. I upgraded from 2016 to 2019 and had to install the newer Measurement Studio. I did the following steps:
