System.ArgumentOutOfRangeException: DateTime.
I am getting the following error when I go to run my application.  I am trying to graph a value vs DateTime.  The DateTime and value are stored in a database.
Error:
System.ArgumentOutOfRangeException: Only double values within a range of 0, or DateTime.MinValue, to 315537897599, or DateTime.MaxValue, can be converted to DateTime.
Parameter name: source
My code:
Dim start As DateTime
Dim finish As DateTime
Dim increment As TimeSpan
start = Session(
"periodStartSpanDTM")
finish = Session(
"periodEndSpanDTM")
increment = TimeSpan.FromMinutes(30)
Dim xAxis As XAxis = graph.XAxes(0)
Dim yAxis As YAxis = graph.YAxes(0)
xAxis.Mode = AxisMode.Fixed
xAxis.AutoSpacing =
False
xAxis.MajorDivisions.Base =
CType(DataConverter.Convert(start, GetType(Double)), Double)
xAxis.MajorDivisions.Interval =
CType(DataConverter.Convert(TimeSpan.FromDays(1), GetType(Double)), Double)
xAxis.MinorDivisions.Interval =
CType(DataConverter.Convert(TimeSpan.FromHours(1), GetType(Double)), Double)
xAxis.Range =
New Range(CType(DataConverter.Convert(start, GetType(Double)), Double), CType(DataConverter.Convert(finish, GetType(Double)), Double))
Dim Label As String = ddlLabels.SelectedItem.Text.ToString
Dim Units As String = ddlLabels.SelectedValue.ToString
Dim Points As Double
Dim rtimes As DateTime
Dim Time As Double
Dim myConn As OleDbConnection = New OleDbConnection("ConnectionString")
Dim myCmd As OleDbCommand = New OleDbCommand("Query Statement", myConn)
myConn.Open()
Dim aReader As OleDbDataReader = myCmd.ExecuteReader()
While aReader.Read
Points =
CDbl(aReader("value"))
rtimes = aReader(
"acqGMT")
Time =
CDbl(DataConverter.Convert(rtimes, GetType(Double)))
ls.Text +=
"Value(" & aReader("acqGMT") & "): " & aReader("value") & "<Br />"
graph.PanXY(Time, Points)
End While
myConn.Close()
(4,247 Views)
Please follow David's advice in the duplicate forum here.
In the future, it may be better to keep all forum posts to one thread rather than having multiple threads about the same issue. This way there is only one place that people will go to help you out on the subject.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(4,233 Views)
