ScaleTransform name cannot be found in the name scope of System.Windows.Controls.ControlTemplate
I'm not sure what I'm doing wrong here.
I have a simple graph with 4 plots.  When I click on the Y or X axis last/first value (to change the range), I get this exception:
'ScaleTransform' name cannot be found in the name scope of 'System.Windows.Controls.ControlTemplate'
I'm pretty sure some time ago this used to work.  Could someone please give me a pointer here?  Thanks!
<ni:Graph x:Name="GraphRefNode">
<ni:Graph.Axes>
<ni:AxisInt32 Orientation="Horizontal" Label="Frame"/>
<ni:AxisDouble/>
</ni:Graph.Axes>
<ni:Graph.Plots>
<ni:Plot Label="X" />
<ni:Plot Label="Y" />
<ni:Plot Label="Z" />
<ni:Plot Label="S" />
</ni:Graph.Plots>
</ni:Graph>
(3,558 Views)
I created a new WPF project and copied your example XAML into the main page: unfortunately, this did not reproduce the issue you are seeing.
Do you have a full project example using this XAML that does reproduce the issue?
~ Paul H
(3,533 Views)
Hi Paul,
You put me on the path to trace this issue (by process of elimination) to this open source GUI library:
https://github.com/MaterialDesignInXAML/MaterialDesignInXamlToolkit
If I don't include one of the Merged Dictionaries, all works as expected.
I can provide you with the bare-bones project to look at this but I can only assume you don't want to look at it because it's happening due to 3rd party library 🙂
Let me know either way.
Thank you!
(3,531 Views)
Accepted by kirko7
Yes, if you have tracked the issue down to a 3rd-party library, then I would suggest contacting the 3rd party 🙂
~ Paul H
(3,529 Views)
Hi Paul,
Just FYI, this issue is mysteriously gone with NI 2019.  I didn't get to the bottom of this but in the end it doesn't really matter anymore.
So just FYI whoever runs into something similar.
(3,482 Views)
