Runtime Error - Can not load nianlys.dll
Hi
I have developed an application using VS2005 with Measurement Studio 8.1
I have used VS2005 to publish the program which creates a setup file. I use the setup file to install the program on a deployment machine however when I run the program it gets a runtime error saying that it could not load the nianlys.dll library.
I have included the NationalInstruments.Analysis.Professional dll as a prerequesite but the nianlys.dll does not seem to get picked up. How do I get around this problem so I can deploy my software to the target machine?
Cheers
Adam
(4,606 Views)
Hi Adam,
The merge module for the Analysis library probably wasn't auto-detected. See steps 15 and 16 in this KB. For additional info see the Deploying Measurement Studio Windows Applications section in the Measurement Studio Help.
Test Engineer - CTA
(4,595 Views)
Hi
Thanks for the info. Have been able to create a setup project which will pick up the dependencies correctly using this method.
It is unfortunate tho that I can't use the Publish feature within the VS2005 Application Properties.
Adam
(4,587 Views)
Adam -
I have recorded your request for Click-Once support for Measurement Studio libraries.
There is a deployment convenience/performance trade-off in play here. The analysis library .NET library utilizes unmanaged code, including the Intel Math Kernel Libraries (MKL) to provide processor-optimized mathematical functions. Being unmanaged libraries, they cannot be Click-Once deployed directly. One option would be for us to provide a Measurement Studio bootstrapper installer. Your customer would need to run this bootstrapper on their machine once. You could then use Click-Once deployment for your applications that depend on the Measurement Studio libraries. Would this solution be acceptable in your scenario?
David Rohacek
(4,577 Views)
Hi David
I would probably lean towards keeping the current solution of deployment in that case. Ideally I like to keep it as simple as possible for the client to install the application. What I liked about the inbuilt publish feature is that I can easily publish it to a web server which the client can access either for the initial install or for automatic upgrades.
I appreciatte your consideration though.
Cheers
Adam
(4,567 Views)
