Programmatically change AI Channels properties?
I'm creating a custom data logger application for my company using a cDaq-9184 chassis with a 9205 AI module in it.  Each channel will have its own waveform graph on the UI. I'm to the point now where I can apply an anolog voltage (-10 to 10 VDC) to each of the physical channels and see it streaming continous on each WFG on the UI.  I have a functionality where I want to be able to not only change the scaling from the UI, but also the scale type (linear, Ranged Map, Table).  So this is where I am stuck.  How do I do this?  The documentation has me hazy and I could use some more guidance.
Below is a snapshot of the UI for this.  When a user clicks the "download" button, I want to change the scale type and scaling parameters of whichever channel the combobox is on, in this case channel 9 (ai10).  Do I need to create a new task every time I do this?  When is OnTaskCreated called in the DaqTask1.User.vb?  I tried the following code in the download button click event :
 Dim MyTask As New NationalInstruments.DAQmx.Task
        MyTask = New DaqTask1
This did not fire OnTaskCreated in the User.vb file.
(4,636 Views)
To change the scaling type for a plot, you invoke the scaling on the plot object.  So, if you have a graph called "graph" with a plot called "waveformPlot", you could change the scaling on the x-axis of that plot to Logarithmic with the following line:
waveformPlot.XAxis.ScaleType = ScaleType.Logarithmic
So for the functionality you're looking for, I would have a selector that selects the scale type you want and then in the callback for the "download values to controller" button, process that value and set the appropriate scale type.
(4,604 Views)
