‎10-26-2004 03:31 PM
‎10-26-2004
04:43 PM
- last edited on
‎06-08-2026
10:43 AM
by
Content Cleaner
Hello
The DAQ Assistant is code generation and configuration tool that is provided as a part of Measurement Studio. Measurement Studio provides .NET class libraries for analysis, User interface controls and also provides integration tools for Visual Studio .NET 2003. The DAQ Assistant allows you to generate C# or VB.NET code with a few clicks of the mouse and allows you to quickly set up a measurement.
I'm assuming the hand book you are referring to is the NI-DAQmx Help file. If you do not have Measurement Studio, you can check out some of the .NET DAQmx examples that are installed with the NI-DAQ driver ( provided you installed support for .NET 1.1 when you installed the DAQmx driver). You can find the examples
under ..\Program Files\MeasurementStudio2003\DotNET\Examples\DAQmx. You do not need Measurement Studio to run these examples. These will demonstrate how to use the DAQmx .NET class libraries in C# and VB.NET.
Hope this helps
Bilal Durrani
NI
‎10-27-2004 09:46 AM
‎10-27-2004 01:53 PM
‎10-27-2004 05:06 PM
‎10-28-2004 02:04 AM
‎10-28-2004 02:54 AM
‎10-28-2004 08:19 AM
‎10-28-2004 11:47 AM
‎10-30-2004 07:55 AM
