annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Polynomial Function
I am using 30 day eval version of Measurement Studio . The problem is that I am getting different output from the matlab polyfit. I am using PolynomialFit function.
I am giving the following input -
Dim xData() As Double = {0.0, 1.0, 2.0, 3.0, 4.0, 5.0}   Dim yData() As Double = {1.0, 2.7, 7.4, 150.0, 80.0, 220.0}   Dim temp() As Double = NationalInstruments.Analysis.Math.CurveFit.PolynomialFit(xData, yData, 3, NationalInstruments.Analysis.Math.PolynomialFitAlgorithm.LU)
And getting the following output-
-4.2809523809519066  8.55476190476141  36.790476190475822  79.509523809524  135.79523809523855   204.73095238095217
Where matlab code produces the following output -
-0.15278   8.15833   4.83016  -4.28095
Also the length of the output is  equal to the input lent where as it should be =order + 1.
Arnab
Messaggio 1 di 5
4.646Visualizzazioni
Hello Arnab -
The output you are seeing is the fitted data.  If you would like to get the coefficients back, you should use one of the overloaded methods that contains the output parameter coefficients.  Once you do this, your coefficients should match up.
Please let us know if you have any more questions.
NickB
Messaggio 2 di 5
4.634Visualizzazioni
Nick,
Thanks for your help.Can you give me a sample code using the overloaded methods that contains the output parameter coefficients ?
Arnab
Messaggio 3 di 5
4.607Visualizzazioni
Hey Arnab,
No problem - here's a short snippet, let me know if you have any further questions:
double[] xData = { 0.0d, 1.0d, 2.0d, 3.0d, 4.0d, 5.0d };
double[] yData = { 1.0d, 2.7d, 7.4d, 150.0d, 80.0d, 220.0d };
// here, coeffs is the variable that will contain the data
// that you are looking for
double[] coeffs, fittedData;
double mse;
fittedData = CurveFit.PolynomialFit(xData, yData, 3, PolynomialFitAlgorithm.LU, out coeffs, out mse);
Just for future reference, we do have code snippets for most of our analysis methods in our documentation.  In this case, the most complex overload
public static double[] PolynomialFit(double[], double[], double[], int, PolynomialFitAlgorithm, int[], double[], out double[], out double);
has the code snippet.  I've found that the easiest way to find this documentation is to use the index to search for the method name in question.  This will bring up a page of all the available overloads, and generally the most complex overload will have a snippet for your inspection.
NickB
Messaggio 4 di 5
4.604Visualizzazioni
Nick,
Thanks a lot for your help.I now get my required coefficient.
Arnab
Messaggio 5 di 5
4.590Visualizzazioni
