Point-by-Point Filter
I would like to know how to do a point by point filter, in the Help the point-by-point filter is referred but it mentions LabView and I do not find how to implemented in C#.
I am using a NarrowbandFirLowpassFilter and NarrowbandFirHighpassFilter. FilterData accepts only arrays
public double[] FilterData(
	double[] inputData
If not possible with this filter, can you recommend me which filter to use?
(4,810 Views)
Hey Ezequiel,
Below are some links to the different filter types and how to use them.
Mohammad Khawas
Technical Support Engineer
Support
ni.com
(4,705 Views)
Hi Mohammad,
Thanks for your response.
I see still the method:
public double[] FilterData(double[] inputData)
But I still do not now how to do a point by point filter, calling FilterData seems to delete the history of the Filter, so I cannot call it with over an over with an array with only one element.
So the question remains how to do this: http://zone.ni.com/reference/en-XX/help/375857B-01/mstudioanalysis/point_by_point_analysis/
Bests,
Ezequiel
(4,681 Views)
The Butterworth filters have history between two FilterData calls.
(4,662 Views)
How can I interpret the documentation to know that? I am really struggling with the documentation and examples 😞
And are there also FIR Point-by-Point or only IIR?
Best regards, Ezequiel
(4,659 Views)
It seems that the filters with memory between FilterData calls contains the Reset method.
(4,655 Views)
