03-04-2022 01:05 PM
In our application, we are trying to detect the time that a projectile makes contact with a surface by monitoring the acceleration/vibration on the surface. I set up an analog input task with continuous sampling and tried to configure a trigger to detect an input signal above a threshold. This task consists of three input channels to monitor the accelerometer and a couple other inputs. I use an AnalogMultiChannelReader to periodically read the values of the channels to display to an operator.
The code looks vaguely as follows:
Create input channels (x3)
Configure task timing
Configure multi channel reader
Manually verify the task
Configure trigger
(Eventually) Retrieve timestamp of latest trigger event
Prior to configuring the trigger, I was able to read data from all three channels. I added the code for the trigger and now cannot load my application due to a -200077 error stating:
"Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: NationalInstruments.DAQmx.ReferenceTrigger.Type
Requested Value: NationalInstruments.DAQmx.ReferenceTriggerType.AnalogEdge
Possible Values: NationalInstruments.DAQmx.ReferenceTriggerType.DigitalEdge, NationalInstruments.DAQmx.ReferenceTriggerType.None"
As far as I can tell from the documentation provided, any Reference Trigger should be able to be configured with an Analog Edge trigger.
Is this a limitation for this specific board that I could not find in the documentation? Or is there another method to configure the channels/task/trigger? Any help or ideas are appreciated. Thanks!
