One compilation on several FPGA- systems
I have several FPGA- systems. Some of them should do the same things.
Now I'm asking myself is it possible to compile the programm only once and´Copy it to the other systems. Or do I have to compile it on every system.
I do not only have the pure FPGA programm, I'm using also a host programm to communicate with user inputs.
Thanks Ruediger
(3,151 Views)
Hello Rüdiger,
as you can see from the target selection option "compile only", you may compile your VI for every kind of supported fpga-target offline.
Once you have compiled your VI for a special hardware (PXI-7831R, PCI-7831R, PXI-7811R, ... cRIO-900x ...), you can open its reference
in the host-interface VI and select the right (present) hardware now or use the external VISA-Input option to select your FPGA-resource
programmatically.
This link should be good illustration about the topic and documents an useful tool:
Regards Thomas.
Message Edited by Tobel on 08-05-2005 03:47 AM
(3,146 Views)
