ObjectDisposedException in NationalInstruments.ui.windowsForms.dll.
I am getting ObjectDisposedException in NationalInstruments.ui.windowsForms.dll. It's version in my computer is 8.1.20.256. I tried to access the version 8.0.11.237 got installed by the MStudio800VS2005Patch.exe. I am failed to achieve this since this version is a lower version and not compatible with Measurement studio 8.1 . Can u pls help me to fix this.
(3,625 Views)
Hi Jasi,
Just to make sure, you are using Measurement Studio 8.1 with Visual Studio 2005 correct?  Does this occur when you try to run any of the Measurement Studio examples?  Is this with C# or VB .NET?  Also would it be possible to post a small application or assembly that exhibits the behavior you are describing?
Pat P.
Software Engineer
(3,614 Views)
