NumericTextBoxDouble Binding Initial Value
I have a ni:NumericTextBoxDouble binded OneWayToSource to a Property. How do I set the Initial Value, which is show (an set) by starting up my program? Now it is showing 0.00.
<ni:NumericTextBoxDouble
x
:Name="YMax"
Value="
{Binding Path=MyYMax, Mode=OneWayToSource, ValidatesOnExceptions=True }"
InteractionMode
="ArrowKeys, ScrollWheel, TextInput"
Width
="58"
Margin
="0,10"
Cursor
="IBeam">                     <ni:NumericTextBoxDouble.ValueFormatter>                         <ni:GeneralValueFormatter  Format="0.00" ShortFormat="{x:Null}"/>                     </ni:NumericTextBoxDouble.ValueFormatter> </ni:NumericTextBoxDouble>
(6,291 Views)
I believe you can set FallbackValue to get a default value when using a OneWayToSource binding.
~ Paul H
(6,286 Views)
ni:NumericTextBoxDouble doesn't seem to have a FallbackValue property...
(6,262 Views)
I solved the Issue with the following Workaround:
I set the Binding type to TwoWay, and gave the Property to a default value. It works, but not a perfect model of my data handling.
(6,257 Views)
Accepted by jtamaska
To clarify, I meant the FallbackValue property on Binding itself:
    <ni:NumericTextBoxDouble Value="{Binding Path=MyYMax, Mode=OneWayToSource, ValidatesOnExceptions=True, FallbackValue=1.1}" ...
~ Paul H
(6,253 Views)
I didn't think of that 😞 That solves it! Thank you!
(6,238 Views)
