cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Network variable problem in 64 bit application
Resolvido!
Ir para a solução
I use only the libraries from Measurement Studio 2015. That is the "newest" what NI has released. The Visual Studio version is not an issue.. It is needed also some libraries from Visual Studio 2013 to put the SW working so I have also VS 2013 in the development computer.. Officially Measurement Studio supports only VS 2013.
BR,
Ilkka
Mensagem 11 de 34
3.430Exibições
Will send us the code that you are facing the problem on, we would like to replicate the issue on a PC.
Regards
Mensagem 12 de 34
3.419Exibições
I made a new test application by using Visual Studio 2013. If you compile and run that in 64 bit mode there is the same error. But in 32 bit mode it is OK. Please test the attached application.
Mensagem 13 de 34
3.409Exibições
Here is an another test. I copied ninetv.dll into the bin directory. So it is found now but in a wrong format:
Mensagem 14 de 34
3.407Exibições
Hi, We just escalated this issue, expecting to have the answer soon.
Thanks for your patience.
Regards.
Mensagem 15 de 34
3.389Exibições
The last error message indicates that there is a mismatch issue, namely a 64-bit process is trying to call into a 32-bit DLL. In Measurement Studio 2015 the NationalInstruments.NetworkVariable.dll works for both 32 and 64-bit processes and We only have one copy of ninetv.dll which should also work for both.
We see that the referenced documentation which indicates in older versions did have a separate 64-bit implementation, ninetv64.dll. It may be possible that you had an old version on your system that is 32-bit specific which could cause this problem.
Can you check the version of ninetv.dll on your system?
Note that since ninetv.dll is shared by all NI products using Network Variables that it should be the version of the highest NI software on your system - in our case that's CVI 2017. The version you should download must be at least a 15.x version (since you use MStudio 2015 on your system).
Finally, is this error happening on your development system, deployment system, or both?
Mensagem 16 de 34
3.374Exibições
Hi, here is the ninetv.dll what is used. Version 15.0.1.239:
BR,
Ilkka
Mensagem 17 de 34
3.370Exibições
Can you please answer the following two questions:
  • Is this error happening on your development system, deployment system, or both?
  • Can we get a fusion log from your system?
    • A fusion log will show us detailed information about how the .NET run-time is locating and loading dependencies, which hopefully will indicate why this assembly load is failing.
    • Also, disable fusion logging after sending it to us - if you leave it on the fusion logs can grow quite big.
Best regards
Basel
Mensagem 18 de 34
3.353Exibições
  1. Yes, the error is happening in both systems.
  2.  The Fusion logs are attached in this message. There are two cases:
    • Case 1: The ninetv.dll file is not copied in bin directory
    • Case 2: The ninetv.dll file is copied in the bin directory
I used the sample Program posted into this thread before. Not our original software but the results are the same.
BR,
Ilkka
Baixar tudo
Mensagem 19 de 34
3.345Exibições
Can you please, verify which location you are pulling ninetv.dll from? Put the whole path or screen shot it.
Thanks.
Basel
Mensagem 20 de 34
3.331Exibições
