Need example of serial session event handler in visual basic (2005)
New to both Visual Basic (.net 2005) and the Measurement Studio plugin with NI-Visa. I want to test the Visa serial (and later USB) I/O in a simple read com port app. Our device continually sends data out in a record format and our GUI needs to receive it but not spend all its time waiting. The data is sent at 4800 baud so it's pretty slow and an event handler that fires on a character received and then puts in a circular buffer is all I think we need. Any example code would be greatly appreciated. We are evaluating the Measurement Studio plugin so this would really help with our decision to go with it.
Alex
Message 1 of 9
(6,602 Views)
ajs,
There is a simple example of using VISA in VB.NET located at C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\Visa\SimpleReadWrite\vb as long as you installed VISA to the default directories. Also, Measurement Studio includes the Instrument I/O Assistant which is a graphical sort of wizard that helps create serial and GPIB calls using VISA.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
Message 2 of 9
(6,591 Views)
Hi Brandon,
We tried the example code you mentioned (SimpleAcynchronousReadWrite) but haven't had a lot of success with it. It's not doing what we hoped it would do which is to sync up to the data records sent by our product. The data rate is slow (4800 baud) with 106 bytes of data sent every .4 seconds continuously.
Alex
Message 3 of 9
(6,579 Views)
Hi Brandon,
Could you please give me a little more detail on what you mean by "sync up to the data records"? Are you able to receive the data from your instrument? Please let me know, and I will do my best to help out. Thanks!
Ebele O.
Message 4 of 9
(6,542 Views)
Hi Ebele,
Our product sends record data at the rate of 106 bytes (hex, not ascii) every .4 second without quierying so our com routine is just listens. We tried "ReadByteArray()" called at a rate to read every record and it keeps losing data. A data record starts with three 0's, which is how we sync to it. What happens is we keep losing the start of the data record and don't know why. We also tried "BeginRead" and "OnReadComplete" with similar unsuccessful results.
Alex
Message 5 of 9
(6,541 Views)
Hi Alex (I am sorry I called you Brandon in my previous post. oops!),
Do you always lose the first part of the data, or is it random? How often are you reading data from the port, and how many bytes are you reading each time? ( I assume you are reading in some kind of loop). You can use the VISA "Number of bytes at serial port" property to determine the number of bytes to read. Could you give me an example of what data your device sends and what data you are reading back for a few iterations of your loop? Also, could you show me a snippet of the code you are using to read from the port. Thanks!
Message Edited by _Belle on 03-22-2007 02:09 PM
Ebele O.
Message 6 of 9
(6,496 Views)
Hi Ebele,
Thanks for your reply. We have a product called a "tool" that is used to locate the drill bit for oil/gas/coal drilling. The tool sends back data to a power supply that then sends data to our GUI running on a PC. The tool data is sent as a record of 106 bytes and it is sent every .4 seconds or so. The interface to the power supply can also be a USB connection but the data rates are the same. The serial port transmits at 4800 baud, no parity, 1 stop, and no handshaking.
The code I played with uses the "ReadByteArray" method and it is called after a timer event. I've played with the interval and timeout parameters and got it so it could read good but still would start missing records and sometimes hangup.
Thanks, Alex.
Here is a code snipet:
Private Sub RecPort_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles RecPort.TextChanged
Dim comstr As String
If RecPort.SelectedItem <> Nothing Then
comstr = RecPort.SelectedItem
If ComPort <> comstr Then
ComPort = comstr
If VisaResourceStr <> Nothing Then
mbSession.Dispose()
End If
Select Case ComPort
Case "COM1"
VisaResourceStr = "ASRL1::INSTR"
Case "COM2"
VisaResourceStr = "ASRL2::INSTR"
Case "COM3"
VisaResourceStr = "ASRL3::INSTR"
Case "COM4"
VisaResourceStr = "ASRL4::INSTR"
Case "COM5"
VisaResourceStr = "ASRL5::INSTR"
End Select
Dim SerSess As New VisaNS.SerialSession(VisaResourceStr)
mbSession = SerSess
'mbSession.Timeout = 10000
SerSess.BaudRate = 4800
SerSess.StopBits = StopBitType.One
SerSess.Parity = Parity.None
SerSess.FlowControl = FlowControlTypes.None
SerSess.Timeout = 100
SerSess.DefaultBufferSize = 2048
End If
End If
End If
End Sub
Private Sub Start_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Start.Click
Timer1.Interval = 300
Timer1.Start()
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
read_tool()
End Sub
Private Sub read_tool()
Dim rbarray() As Byte
Try
rbarray = mbSession.ReadByteArray(106)
Catch ex As Exception
'MessageBox.Show("Exception: " & ex.Message, "Exception", MessageBoxButtons.OK, MessageBoxIcon.None)
'Exit Sub
End Try
If (Not (rbarray Is Nothing)) Then
ib.Copy(rbarray, ib, rbarray.Length)
copy_records(ib, rbarray.Length)
End If
Else
'MessageBox.Show("Enter a valid COM port", "Error", MessageBoxButtons.OK, MessageBoxIcon.None)
End If
End Sub
Message 7 of 9
(6,479 Views)
I tried the "AvailableNumber" and that worked! Still testing but so far no crashes
Thanks Ebele.
Alex
Message 8 of 9
(6,463 Views)
Hi Alex,
I am glad the function worked for you, and you are able to get things working now.
Ebele O.
Message 9 of 9
(6,453 Views)
