NationalInstruments.Controls.Internal.ScaleLabeledDivisionsPresenter issue
Hi everyone!
I have been struggling with an issue with the NationalInstruments library in my C# application, specifically when I am undocking one of those channels in my app in a new window, from the main window of the app, as shown in the picture, I have two ni:IntensityGraph, with ni in xaml being: xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation". The issue is, when clicking on any of the axis limits, the system throws an exception with the message: "Object reference is not set to an instance of an object.", with the stacktrace:
   at NationalInstruments.Controls.Internal.ScaleLabeledDivisionsPresenter`1.b(EditorPosition A_0)
   at NationalInstruments.Controls.Internal.ScaleLabeledDivisionsPresenter`1.a(Object A_0, MouseButtonEventArgs A_1)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
So, at NationalInstruments.Controls.Internal.ScaleLabeledDivisionsPresenter`1.b(EditorPosition A_0), it seems to be crashing. I have tried everything so far, even creating a new V+VM instance, cloning the properties rather than parsing the existing ones, with no luck. Has anyone encountered this issue? If so, what was the cause and the solution?
Thanks!
(1,136 Views)
That sounds like an issue with the text control that allows you to interactively edit the minimum/maximum on a scale.  On the horizontal and vertical axes for your intensity graph, you might want to examine the EditRangeValueFormatter on your MajorDivisions, or set the axis to InteractionMode="None" to disable interactive editing.
~ Paul H
(1,008 Views)
