NI USB-8451 .net c# support
I'm looking into probably getting the NI USB-8451 but have a few questions.
I'll be using c# for making an app.
Is there .net c# library for the usb-8451 so I can take advatnage of i2c , spi and all that?
Message 1 of 11
(9,054 Views)
Accepted by cheece2001
Hi cheece2001,
To my knowledge there is unfortunately only a C API for the USB-8451. The user manual, found here: http://www.ni.com/pdf/manuals/371746e.pdf details all the C commands. Examples also come with the NI-845x driver download if you want to look at these. This downlad is found here: http://www.ni.com/download/ni-845x-15.0/5611/en/ The driver readme also only lists support for "Microsoft Visual C/C++ 6.0 (or newer)"
Hope this helps!
Selene
Message 2 of 11
(9,036 Views)
hi
I'll be using c# for making an app too.
can you share your source code ?
I need that code very much.
Message 3 of 11
(5,973 Views)
Until now, i was only able to communicate and use the dio function as a switch and still looking on how to use the i2c function in c#
Message 4 of 11
(5,036 Views)
You've to call the c dll in C#.
We have succeeded in using all the features of the 845x library in C# but couldn't share any of that development as those are proprietary.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
Message 5 of 11
(5,032 Views)
Just tried to call all of those and managed to resolved all of the thrown errors, the master acknowledged the slave address already but my problem lately was; when I run my code, it stops right after the  ni845xI2cWriteRead.TIA function.
Message 6 of 11
(5,026 Views)
At last, I managed to make it work with a lot of exerted effort for several days.
Message 7 of 11
(4,972 Views)
If it is not proprietary, please attach the code as reference for others.
Santhosh
Message 8 of 11
(4,960 Views)
Can you post the Source Code? Thanks
Message 9 of 11
(3,282 Views)
proprietary?  If you created some special interpreter software but if just taking the NI845x.dll and using visual studio to make some adapted version of the dll that runs in C# then it shouldnt be proprietary.  when I solve it, will hopefully make it public for the world since its not really fair that NI refuses to help solve this.
No one write a new app in C in 2024.  We use C#.  NI must know how to do this and wants to not help, when it comes time to specify a vendor solution we will assuredly be looking elsewhere for this reason.
Message 10 of 11
(2,723 Views)
