NI USB-6009 interfacing with VB.NET
Hi I am completely new to NI hardware. My question is how can you interface 6009 with VisualBasic.NET by it self. I need to read couple digital input ports and based on input I need to control couple output ports. Please Help.
Thanks.
(5,177 Views)
Hi Kiro,
I'm assuming that you will be programming your device with the NI-DAQmx drivers (this is recommended).  National Instruments provides a native .NET API for NI-DAQmx. This is available as a part of the NI-DAQmx driver.  There is a Knowledgebase article on our website here that provides more details on programming NI-DAQ in Microsoft Visual Basic .NET.  In addition, when you include .NET support in the installation of your DAQmx drivers, documentation is included and can be found in Start>Programs>National Instruments>NI-DAQ>NI-DAQmx .NET Framework 2.0 Help.
Andrew W
(5,166 Views)
Thanks Woost. I think i got it to work. I found those files and i used tham as a template for my litle application. Appriciate the the help.
(5,162 Views)
