NI-Industrial Communications for EtherNet/IP Compatible
Hallo,
simple question: Is it possible to use the NI-Industrial Communications for EtherNet/IP toolkit with Measurement Studio without a stand-alone LabVIEW installation?
Edit: Also are any licences required, when an application developed with Measurement Studio and the EtherNet/IP toolkit is deployed to target systems?
Cheers
(2,663 Views)
Hello Ingfu.
Could you please provide me information about your computer  OS, also the versions of NI Measurement Studio and NI Industrial Communications for Ethernet/IP?
NI-Industrial Communications for EtherNet/IP has the following requirements:
  • LabVIEW Base Development System
  • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
Meri
(2,434 Views)
