Log Scale on Complex Graph
Hello! Is there a possibility to change the scale of a Complex Graph X-Axis to logarithmic scale? I know that for Waveform Graph it's possible, but not for Complex Graph. Is there any hint? Thanks best regards, Matthias
(3,446 Views)
Hi Matthias,
I used a shipping example and inserted the following line. I'm not sure if that works with your code or if you tried that already but still worth a try.
xAxis.ScaleType = ScaleType.Logarithmic
C:\Users\Public\Documents\National Instruments\MStudioVS2008\DotNET\Examples\UI\WebForms\UI.WebForms.Examples.2008.sln
Stefan
(3,418 Views)
