Legend Item Image
Can I  override the Legend Item Image? i.e. make the image a different solid color for each item in the legent item collection. The waveform line and plot points are difficult to see.
(3,591 Views)
Accepted by topic author JerryBailey
Hello -
You can do this by creating a class that implements ILegendItemSouce and drawing the solid color in the the DrawLegendItem method.  Your code might look similar to the following:
class SolidColorLegendItemSource : ILegendItemSource
  private Color itemColor;
  public SolidColorLegendItemSource(Color color)
    itemColor = color;
  public void DrawLegendItem(ComponentDrawArgs args)
    // create the bounds for the solid fill rectangle
    int top = args.Bounds.Height / 2 + args.Bounds.Y - args.Bounds.Height / 4;
    int height = args.Bounds.Height / 2;
    int left = args.Bounds.X;
    int width = args.Bounds.Height;
    args.Graphics.FillRectangle(new SolidBrush(itemColor), new Rectangle(new Point(left, top), new Size (width, height)));
  public event EventHandler Disposed;
  protected virtual void OnDisposed(EventArgs e)
    if (Disposed != null)
      Disposed(this, e);
  public event EventHandler LegendItemChanged;
  protected virtual void OnLegendItemChanged(EventArgs e)
    if (LegendItemChanged != null)
      LegendItemChanged(this, e);
Let me know if you have any questions -
NickB
(3,584 Views)
