Labview struct(cluster) reflected in propertygrid
Hi there and good evening,
When buidling an InteropAssembly with Labview, clusters are represented as type struct in .net (c#) .
I've tried to put this struct in the PropertyGrid control, but nothing happens.
It would be nicest if there is way do get this working. Just give the user a PropertyGrid for a whole ConfigurationCluster.... At least for BaseTypes ????
Or ist the only way to write a wrapper?
Best Regards and Good
Evening
(3,408 Views)
Evening,
have you seen this post? It seems to me, that the question there is quite comparable to yours. You should read the answers from smercurio.
In short: It is not possible in this way. LV clusters are no .NET classes and therefore you cannot put them into PropertyGrids.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,397 Views)
