LabVIEW Formula Parsing
I am attempting to read formula strings from an array of clusters.  No problem, works great. Now I want to evalute the string formulas to determine if the values are greater or less than what is specified in the formula ( BatteryVoltage < 5.0 ).  The current string to formula evaluate funtions do not handle "<>&|" operators.  Any ideas that won't cost an arm and a leg???
Larry
(6,600 Views)
Hi lcarner
One thing you can try is evaluating those values using the <>& nodes in LabVIEW. You can take the output values of the Formula Parsing VIs and evaluate them using the native LabVIEW comparison nodes.
Regards
Chris S.
(6,570 Views)
I use the open source library muParser (http://muparser.beltoforion.de/) to evaluate mathematical expressions in my project Open Dyno www.opendyno.com.
(6,558 Views)
A new LabVIEW API for muParser is available on LAVA: https://lavag.org/files/file/295-lv-muparser/
(3,489 Views)
