How to use a USB-6008 with vb.net
I'm trying to talk to a USB-6008 with VB.net. I simply need to set analog out 0 to a voltage. That's it. Anyone have a simple example?
Message 1 of 11
(8,552 Views)
Hi Breeyet,
The USB-6008 uses the DAQmxBase driver software. Currently, DAQmxBase is only officially supported in C and LabVIEW. However, I have found a way to get it to work in .NET languages.
You basically need to declare all of your DAQmxBase functions at the top of your program before using them. The link below describes how to do this in C#.NET and has an example attached. This process should be almost the same for VB.NET.
To get an idea of how to do analog output with your 6008, look at the shipping examples found here:
C:\Program Files\National Instruments\NI-DAQmx Base\Examples
These are C examples, but the functions are used exactly the same in VB.NET. Just make the same calls in the same order and it should work.
http://digital.ni.com/public.nsf/websearch/AF5F4827A953E7B286256F35005E4260?OpenDocument
-Sal
Message 2 of 11
(8,524 Views)
When writing the wrappers, make sure to specify the calling convention to cdecl, since thats how the DAqmxBase functions have been declared. If you dont specify a calling convention attribute, the default of stdcall is used. Check out this link for more examples on DLLImport.
Bilal Durrani
NI
Message 3 of 11
(8,518 Views)
Can anybody please provide some example of how this can be done for use in VB.NET?
THanks a million
Message 4 of 11
(8,385 Views)
Here's an example that I came across for VB.NET.
-Alan A.
Message Edited by Alan A. on 06-03-2005 03:00 PM
Message 5 of 11
(8,089 Views)
Dear Alan,
-The AI_mxBase_VB_DotNet example on how to read Analog input was very useful but we had the following error:
("Namespace or type 'UI' in the project-level Imports 'NationalInstruments.UI' cannot be found.")
-Do you Have another example for the digital input output and for the analog output.
We have the measurement studio .Net 2003, do you have examples for how to benefit from it for the USB-6008
Thank you
Message 6 of 11
(7,834 Views)
Hello gab73,
You will need to add a couple .Net assemblies to use this program. You will need NationalInstruments.Common.dll, NationalInstruments.UI.dll, and NationalInstruments.UI.WindowsForms.dll. All of which install by default to this directory: C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Assemblies\Current. As for other examples, I simply don't think they exist at this particular point in time. DAQmx Base in VB.Net is not an extremely common combination. But you can use the previous example as a guide to creating your own.
-Alan A.
Message 7 of 11
(7,801 Views)
Dear Allen
your example AI_mxBase_VB_dotNet.zip work very good !!
-> Do you Have another example for the digital input or/and output <-
We have USB-6009 and not the measurement studio .Net 2003, only VB.NET 2003
Thank you
Message 8 of 11
(7,730 Views)
I am not aware of any digital i/o examples in vb.net for NI-DAQmx Base. However, the ai example shows how to use the NI-DAQmx Base functions, so you should be able to get a pretty good idea of how to go about it. Also, I would recommend looking at the C Examples for DIO(to see programming flow) that install here: Start>>All Programs>>National Instruments>>NI-DAQmx Base>>Examples>>C Examples.
-Alan A.
Message 9 of 11
(7,685 Views)
Hello Allen
my translation from Ansi C -> VB.NET
[DAQmxBaseCreateDOChan,DAQmxBaseWriteDigitalU8]
P0.0..P0.7 and P1.0..P1.3 always 5 Volts
can you help me what's wrong ?
_
Public Shared Function DAQmxBaseCreateDOChan(ByVal taskHandle As TaskHandle, ByVal lines As String, ByVal nameToAssignToLines As String, ByVal lineGrouping As Integer) As Integer
'int32 DAQmxBaseCreateDOChan (TaskHandle taskHandle, const char lines[ ], const char nameToAssignToLines[ ], int32 lineGrouping);
End Function
_
Public Shared Function DAQmxBaseWriteDigitalU8(ByVal taskHandle As TaskHandle, ByVal numSampsPerChan As Integer, ByVal autoStart As System.UInt32, ByVal timeout As Double, ByVal dataLayout As System.UInt32, ByVal writeArray As Integer, ByRef sampsPerChanWritten As Integer, ByRef reserved As System.UInt32) As Integer
'int32 DAQmxBaseWriteDigitalU8 (TaskHandle taskHandle, int32 numSampsPerChan, bool32 autoStart, float64 timeout, bool32 dataLayout, uInt8 writeArray[ ], int32 *sampsPerChanWritten, bool32 *reserved);
End Function
Private Function write_digital_usb()
' Task Parameters
Dim [error] As Integer = 0
Dim taskHandle As TaskHandle = Convert.ToUInt32(0)
' Channel parameters
Dim lines As String = "Dev1/port0"
Dim lineGrouping As Integer = 1 ' 1 = One Channel For All Lines [DAQmx_Val_ChanForAllLines]
Dim numSampsPerChan As Integer = 0 '0
Dim autoStart As System.UInt32 = Convert.ToUInt32(0)
Dim timeout As Double = 1.0
Dim writeArray As Integer = 1 'bit 0000 0001
Dim sampsPerChanWritten As Integer
Dim dataLayout As System.UInt32 = Convert.ToUInt32(0) ' 0 = Group by Channel [DAQmx_Val_GroupByChannel]
[error] = DAQmxBaseCreateTask("", taskHandle)
[error] = DAQmxBaseCreateDOChan(taskHandle, lines, Nothing, lineGrouping)
[error] = DAQmxBaseStartTask(taskHandle)
[error] = DAQmxBaseWriteDigitalU8(taskHandle, numSampsPerChan, autoStart, timeout, dataLayout, writeArray, sampsPerChanWritten, Nothing)
[error] = DAQmxBaseStopTask(taskHandle)
[error] = DAQmxBaseClearTask(taskHandle)
End Function
Thank you in advance for your Support
Werner G.
Message Edited by Werner G. on 07-01-2005 09:32 AM
Message 10 of 11
(7,654 Views)
