488.2 Task Assistant and Modify Attributes
Hi, I'm  novice with Measurement Studio.  In a new solution building a NI4882Task (a mxb file) I dont know how to modify the VI_ATTR_TERMCHAR_EN (from false to true).  In a query or read step I get timeout errors (VISA Status code: bfff0015).
I need to change this attribute.  Where can I do it ?  Thank you.
(3,157 Views)
there is a property called TerminationCharacterEnabled that you could use to enable termination character in reads. Moreover, you have also TerminationCharacter to set which will be the termination character. I attach you an image of the Measurement Studio Help.
I hope this helps.
crisR
(3,150 Views)
