How to repeat AnalogMultiChannelReader
I'm trying to use PCIe-6343 in Visual Basic 2010 on WinXP and writing codes to measure AI signal,save to text file.
I succeeded single point measurement, so I tried to repeat program using 'For..Next' loop and failed error -50103.
Would you tell me how can I change this sourse code.
I referenced Example file from /Dotnet4.0/Anarog In/Measure Voltage/ContAcqVoltageSamples_IntClk_ToFile
Thanks.
    Private Sub StartContButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles StartContButton.Click
        Dim filecount As Integer
        For filecount = 0 To 1024
            filecount += 1
            AcqFileNum.Text = filecount
            AcqSinglepoint()
            Dim AcqTime As Double = Convert.ToInt32(samplesPerChannelNumeric.Value) / Convert.ToDouble(rateNumeric.Value)
            myTask.WaitUntilDone(AcqTime * 1000)
        Next
    End Sub
    Private Sub AcqSinglepoint()
	'determine filename and fullfilepath
        If runningTask Is Nothing Then
            Try
                'Create a new file for data
                Dim opened As Boolean = CreateDataFile()
                If Not opened Then
                    Return
                End If
                'Create a new task
                myTask = New Task()
                'Create a virtual channel
                myTask.AIChannels.CreateVoltageChannel("/Dev1/ai0,/Dev1/ai1", "", AITerminalConfiguration.Rse, Convert.ToDouble(minimumValueNumeric.Value), Convert.ToDouble(maximumValueNumeric.Value), AIVoltageUnits.Volts)
                'Configure the timing parameters
                myTask.Timing.ConfigureSampleClock("", Convert.ToDouble(rateNumeric.Value), SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Convert.ToInt32(samplesPerChannelNumeric.Value))
                'Verify the Task
                myTask.Control(TaskAction.Verify)
                'Prepare the table and file for Data
                Dim channelNames(myTask.AIChannels.Count - 1) As String
                Dim i As Integer = 0
                Dim a As AIChannel
                For Each a In myTask.AIChannels
                    channelNames(i) = a.PhysicalName
                    i = i + 1
                Next a
                InitializeDataTable(channelNames, dataTable)
                'Add the channel names (and any other information) to the file
                Dim samples As Integer = Convert.ToInt32(samplesPerChannelNumeric.Value)
                PrepareFileForData()
                savedData = New ArrayList
                For i = 0 To myTask.AIChannels.Count - 1
                    savedData.Add(New ArrayList)
                Next
                runningTask = myTask
                analogInReader = New AnalogMultiChannelReader(myTask.Stream)
                'Use SynchronizeCallbacks to specify that the object
                'marshals callbacks across threads appropriately.
                analogInReader.SynchronizeCallbacks = True
                analogCallback = New AsyncCallback(AddressOf AnalogInCallback)
                analogInReader.BeginReadMultiSample(samples, analogCallback, myTask)
            Catch exception As DaqException
                'DisplayErrors
                MessageBox.Show(exception.Message)
                runningTask = Nothing
                myTask.Dispose()
                stopButton.Enabled = False
                startButton.Enabled = True
            End Try
        End If
End Sub
    Private Sub AnalogInCallback(ByVal ar As IAsyncResult)
        Try
            If (Not (runningTask Is Nothing)) AndAlso runningTask Is ar.AsyncState Then
                'Read the available data from the channels
                data = analogInReader.EndReadMultiSample(ar)
                'Plot your data here
                LogData(data)
            End If
            'Display Errors
            TextBox1.AppendText("Error in AnalogInCallBack" + vbCrLf)
            myTask.Dispose()
        End Try
        If Not (runningTask Is Nothing) Then
            'Dispose of the task
            CloseFile()
            myTask.Dispose()
        End If
    End Sub
(5,676 Views)
Hi, I replied to your Japanese post, so I'll keep it short here.
You are using FiniteSample in ContinousSample example.
Please see the folloing examples for correct usage of FiniteSample and ContinousSample
Finite:            \DotNET4.0\Analog In\Measure Voltage\AcqVoltageSamples_IntClk
Continous:   \DotNET4.0\Analog In\Measure Voltage\ContAcqVoltageSamples_IntClk
(5,662 Views)
