How to plot Timestamp vs data on wpf graph
Sir,
I am using wpf graph control in my application. My intention is to plot the data, which consists of Timestamp as X-value and corresponding some float value as Y-value...How can i specify this kind of data to wpf graph?? I have tried the following but this is not correclty displaying the time.
I converted timestamp to double value using ToOADate() method and the X-axis i specified as ni:DateTimeAxis..I have supplied the double Point array as a datasource to the graph..But this is not correctly displaying the time...Can this be sorted out??
(5,963 Views)
The WPF graph has native support for DateTime and PrecisionDateTime values, so you do not need to convert your data to double values first. Simply use a data type that can supply time values, such as AnalogWaveform<TData>. For example:
    // XAML
    <ni:Graph Name="graph">
        <ni:Graph.Axes>
            <ni:AxisDateTime Orientation="Horizontal" />
        </ni:Graph.Axes>
    </ni:Graph>
    // code
    double[] sampleValues = ...;
    WaveformTiming timeValues = WaveformTiming.Create...;
    var waveform = AnalogWaveform<double>.FromArray1D( sampleValues );
    waveform.Timing = timeValues;
    graph.DataSource = waveform;
~ Paul H
(5,955 Views)
