How to plot 3D graph by using C# in Measurement Studio?
I am new in C# programming. Currently I am developing a program using C# language and Measurement Studio 7.1. This program will use for signal processing. So, may I know how to plot 3D graph (waterfall) in my program?  I notice that only 2D graph available in Measurement Studio. Thanks for your help!
(11,880 Views)
Hi Wesley,
The following links will get you up and running:
Creating Intensity Graphs in .NET using the Measurement Studio 3D Graph Control
Using Plot Styles with the Measurement Studio 3D Graph Control
Plotting Intensity Using a Measurement Studio 3D Graph Control
There is no C# Assembly for 3D Graphs, but you can get the same functionality combining the C++ code as in the top example.
Cheers,
David Goldberg
Software R&D
(11,866 Views)
Thanks David.
Is there any exemple running under VB-2010?
I'm having trouble running the 3d chart graph on MS2010.
Thanks in advance.
(6,608 Views)
Hi Ni community :
No idea how to perform a 3d chart on MS2010 -vb.net- under 64 bits?
Is it in your plans for future releases ?
thanks in advance.
(6,556 Views)
Any update?
(6,392 Views)
Elbob,
Sorry for the lack of response. Unfortunately, you are correct, the 3D graph for Measurement Studio is the ActiveX version that is not 64-bit compatible. If you need a 3D graph in 64-bit then you can use the intensity plot, but this only produces 3D data in a sense that color is the third dimension. Currently Measurement Studio does not have an equivalent to the ActiveX 3D graph control. I don't really have any information to provide on future support of this feature, but I would recommend taking the time to place a product suggestion for it. Our development teams typically look at these as the primary source when considering new features.
(6,381 Views)
