Can a graph trace be set to a width of zero?
Am using an old cwui.ocx in a vb.net project(strip chart). I need to hide selected traces but am unable. If I set the trace color to the background color, the active traces are overwritten by the "white" trace(s). If I set them to be off scale I see the vertial line segments as they go off-scale. I cannot set the trace width to anything less than 1. Does anyone have any hints on hiding traces. If I upgraded to a real NI .net graph control, can I set the trace width to zero?
Bartj
(3,786 Views)
Accepted by topic author bartinoregon
I believe there is a trace.visible property you will want to modify.  There is more information on this here:
How do you hide a graph trace
http://forums.ni.com/t5/Measurement-Studio-for-VB6/How-do-you-hide-a-graph-trace/m-p/1692220?require...
Let me know if that works for you.
Shawn S. | NIC
Instrument Driver/IVI PSE
(3,772 Views)
