How to add Table Values in Signal using National Instruments.VeriStand.System Definition API.dll
I’m creating a System Definition File using the National Instruments.VeriStand.System Definition API.dll with C#, but in the API I can add the signal but the Value Table is not adding the data.
The first image shows the SDF made with the DLL and the second image as it should be.
(2,887 Views)
Hi RicardoCastilloValencia,
Because this question is less specifically about C# programming, and more about working with the VeriStand System Definition API, you may find more success posting on the VeriStand forums instead. The VeriStand forums are located here.
Kathryn K.
Technical Support Engineer
http://ni.com/support
(2,858 Views)
