How do I set the read timeout when using channelReader.ReadWaveform?
I am aquiring data using a USB-6210 A/D, and it works great until I try to take a waveform longer than 10s.
When I take a waveform longer than that, I get error 200284, "Some or all of the samples requested have not yet been acquired.  To wait for the samples to become available use a longer read timeout..."
No problem, I thought, I'll just set a longer timeout.  I searched through the documentation, and the only timeout I found was the Watchdog timeout.  When I tried to set that to a longer value,  I get status code -200452 - specific property is not supported by the device or is not applicable to the task.
I am using the code from the AcqVoltageSamples_IntClk.2008 .net sample with C# in Visual Studio 2008, .net 3.5 sp1.
How do I set the timeout so that ReadWaveform() does not timeout?
Here is the code:
privateAnalogMultiChannelReaderchannelReader;
privateAnalogWaveform<double> awf;
publicList<double> GetWaveForm()
    try
        Task getWaveform = newTask();
        getWaveform.AIChannels.CreateVoltageChannel(Channel,"", TerminalConfiguration,RangeMinimum,
                    RangeMaximum,AIVoltageUnits.Volts);
        getWaveform.Timing.ConfigureSampleClock("", SampleRate, SampleClockActiveEdge.Rising,
                    SampleQuantityMode.FiniteSamples, NumSamples);
        getWaveform.Control(TaskAction.Verify);
       channelReader = new AnalogMultiChannelReader(getWaveform.Stream);
       AnalogWaveform<double>[] data = channelReader.ReadWaveform(NumSamples);
       awf = data[0];
       samples = new List<double>();
       for(inti=0; i<NumSamples ; ++i) samples.Add( awf.Samples[i].Value );
       returnsamples;
    catch( DaqExceptionexception)
        MessageBox.Show( exception.Message);
     List<double> l = newList<double>();
     return l;
Curt
(5,031 Views)
Accepted by cfiedler
Hi Curt,
Here is a Knowledge Base that can help you set the Timeout parameter in your code:
Using the DAQmx Task Timeout Property in Visual Studio
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(5,004 Views)
Thanks!  That helps a lot!
Curt
(5,000 Views)
