How do I get timing information from analogwaveform C#
I'm using a USB-6008 and I want to get a timestamp for each sample that I acquire. As you can see in my code I'm using an AnalogWaveform. I found out that I have to set the Timing  enumeration of the WaveformAttributeModes property to gather the time data and include it with your waveform data. But I don't know where to set the WaveformAttributeMode??
        private AnalogMultiChannelReader analogInReaderCheck;
        private int samplesPerChannel = 50;
        private int rateHz = 500;
        private Task checkTask;
        private AsyncCallback analogCallbackCheck;
                    checkTask = new Task();
                    // Create a virtual channel
                    checkTask.AIChannels.CreateVoltageChannel("dev1/ai0:3", "",
                        AITerminalConfiguration.Differential, -1, 5, AIVoltageUnits.Volts);
                    // Configure the timing parameters
                    checkTask.Timing.ConfigureSampleClock("", rateHz,
                            SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, 1000);
                    // Verify the Task
                    checkTask.Control(TaskAction.Verify);
                    analogInReaderCheck = new AnalogMultiChannelReader(checkTask.Stream);
                    analogCallbackCheck = new AsyncCallback(MyCallback);
                    analogInReaderCheck.SynchronizeCallbacks = true;
                    analogInReaderCheck.BeginReadWaveform(samplesPerChannel, analogCallbackCheck, checkTask);
kind regards
Message 1 of 1
(3,620 Views)
