FetchSpectrum Using Python and RFmx
I'm attempting to use RFmx through Python.NET.  The code works up until I try to grab the spectrum using FetchSpectrum():
# create variable name before passing it to .NET method
spectrum = RFmxSpecAnMXSpectrum
# This doesn't work!
specAn.Spectrum.Results.FetchSpectrum('', timeout, spectrum)
Here's the full code:
import clr
import sys
# location of assemblies
assy_path = r'C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\Current'
sys.path.append(assy_path)
clr.AddReference("NationalInstruments.RFmx.SpecAnMX.Fx40")
clr.AddReference("NationalInstruments.RFmx.InstrMX.Fx40")
from NationalInstruments import *
from NationalInstruments.RFmx.InstrMX import *
from NationalInstruments.RFmx.SpecAnMX import *
# VSA Settings
resourceName = '5606_slave'
centerFrequency = 10.0e9        # Hz
referenceLevel = -10            # dBm
externalAttenuation = 0.00      # dB
timeout = 10                    # seconds
span = 1.0e+6                   # Hz
rbw = 100e3
averagingCount = 10
instrSession = RFmxInstrMX(resourceName, '')
# configure VSA
rbwAuto = RFmxSpecAnMXSpectrumRbwAutoBandwidth.True
rbwFilterType = RFmxSpecAnMXSpectrumRbwFilterType.Gaussian
averagingEnabled = RFmxSpecAnMXSpectrumAveragingEnabled.False
averagingType = RFmxSpecAnMXSpectrumAveragingType.Rms
#specAn = instrSession.GetSpecAnSignalConfiguration();
specAn = RFmxSpecAnMXExtension.GetSpecAnSignalConfiguration(instrSession)
specAn.ConfigureRF('',centerFrequency,referenceLevel,externalAttenuation)
specAn.Spectrum.Configuration.ConfigureSpan('', span)
specAn.Spectrum.Configuration.ConfigureRbwFilter('', rbwAuto,rbw,rbwFilterType)
specAn.Spectrum.Configuration.ConfigureAveraging('', averagingEnabled,averagingCount,averagingType)
specAn.SelectMeasurements('',RFmxSpecAnMXMeasurementTypes.Spectrum,bool())
specAn.Commit('')
# execute acquisition
specAn.Initiate('','')
# find peak power in the spectrum
_,pkAmp,pkFreq,freqRes = specAn.Spectrum.Results.FetchMeasurement('',timeout,float(),float(),float())
print 'Peak Power: {:0.2f} dBm at {:0.6f} GHz'.format(pkAmp,pkFreq*1e-9)
A .NET method may require the user to pass the variable name it wishes to
modify as an argument. Python does not support "pass by reference" but the
variable name must exist in python before it can be handed to the .NET method.
The .NET method will simply point to the new instance.
http://nbviewer.ipython.org/github/jonnojohnson/Agilent/blob/master/Python_Automation/Python_Automation.ipynb
instrSession.Close()
Here  is the error:
Traceback (most recent call last):
  File "<ipython-input-172-79fb463146f0>", line 3, in <module>
    specAn.Spectrum.Results.FetchSpectrum("", timeout, spectrum)
ArgumentException: Object of type 'System.RuntimeType' cannot be converted to type 'NationalInstruments.Spectrum`1[System.Single]&'.
   at System.RuntimeType.TryChangeType(Object value, Binder binder, CultureInfo culture, Boolean needsSpecialCast)
   at System.Reflection.MethodBase.CheckArguments(Object[] parameters, Binder binder, BindingFlags invokeAttr, CultureInfo culture, Signature sig)
   at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at Python.Runtime.MethodBinder.Invoke(IntPtr inst, IntPtr args, IntPtr kw, MethodBase info, MethodInfo[] methodinfo)
Any ideas?
Message 1 of 10
(8,739 Views)
See below for a reponse from a colleague that saw this post and is well-versed in the RFmx .NET API:
"I am not able to reply to it due to network issues. Can you please reply to the query and indicate that the spectrum type he/she is using is wrong.
Should actually be
spectrum = NationalInstruments.Spectrum<float> #Present in NationalInstruments.Common assembly"
Hope this takes care of the issue.
Message 2 of 10
(8,730 Views)
Hi JMota,
Thanks for the reply.  I gave that a try, and I received the same error.
# import the "NationalInstruments.Common assembly"
import NationalInstruments
spectrum = NationalInstruments.Spectrum[float]
print spectrum
<class 'NationalInstruments.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]'
For reference, if I eliminate the [float]:
print spectrum
<class 'NationalInstruments.Spectrum`1'>
Message 3 of 10
(8,720 Views)
Got some more info from another colleague. Just passing it along:
"Thats not how you call ref/out parameters from iron python. There are two ways
A. Implicit: you just don't pass ref and out params. And the python will return all ref and out parameters as a tuple.
B. Explicit: use clr.Reference[T] and then pass that."
Hope that sheds some light.
Message 4 of 10
(8,697 Views)
Here is a minimal example that shows how to call FetchSpectrum:
import clr
import sys
clr.AddReference("NationalInstruments.Common")
from System import *
# VSA Settings
specAn.Commit('')
spectrumDataRef=clr.Reference[Spectrum[Single]]();
result=specAn.Spectrum.Results.FetchSpectrum('',10.0,spectrumDataRef);
spectrumData=spectrumDataRef.Value;
print 'Spectrum size: {0}'.format(spectrumData.SampleCount)
Message 5 of 10
(8,678 Views)
I gave that a try, but the clr module doesn't appear to have a "Reference()" method. Perhaps this is an IronPython implimentation, rather than Python.NET?
In[11]: dir(clr)
Out[11]:
['AddReference',
 'FindAssembly',
 'ListAssemblies',
 'NationalInstruments',
 'System',
 '_AtExit',
 '__class__',
 '__doc__',
 '__file__',
 '__name__',
 '_extras',
 'clrmethod',
 'clrproperty',
 'getPreload',
 'setPreload']
Message 6 of 10
(8,664 Views)
Yes this is the IronPython implementation. I wrongly assimed that you were using IronPython.
You implmented this fix.
 Instead of
can you please try
spectrum = NationalInstruments.Spectrum[float](0)
Message 7 of 10
(8,658 Views)
Accepted by topic author jmagers
Ah! That was just about it. Here's what worked:
spectrum = NationalInstruments.Spectrum[System.Single](0)
_,spectrum = specAn.Spectrum.Results.FetchSpectrum('',timeout,spectrum)
Here is the result and the final code for future reference:
import clr
import sys
import os
import matplotlib.pyplot as plt
import numpy as np
# Windows environmental variable for Program Files
program_files = os.environ['ProgramFiles(x86)']
assy_path = os.path.join(program_files,
                         'National Instruments',
                         'MeasurementStudioVS2010',
                         'DotNET',
                         'Assemblies',
                         'Current')
import System
# VSA Settings
centerFrequency = 25.0e9      # Hz
span = 1.0e+6                 # Hz
rbw = 100e3                   # Hz
averagingCount = 10
# Get model number
_,model=instrSession.GetInstrumentModel('',str())
# configure VSA
specAn.Commit('')
# get x data
# get y data
analogwaveform = NationalInstruments.AnalogWaveform[System.Single](0)
_,analogwaveform = specAn.Spectrum.Results.FetchPowerTrace('',timeout,analogwaveform)
# close session
# compute frequency and power
startFrequency = spectrum.StartFrequency
frequencyIncrement = spectrum.FrequencyIncrement
sampleCount = spectrum.SampleCount
stopFrequency = startFrequency + frequencyIncrement*(sampleCount+1)
freqArray = np.linspace(startFrequency,stopFrequency,sampleCount)
power = list(analogwaveform.GetRawData())
# plot results
xscale = 1e-3
plt.plot((freqArray-centerFrequency)*xscale,power,linewidth=2.0)
#plt.ylim(referenceLevel-100.,referenceLevel)
plt.yticks(np.linspace(referenceLevel-100.,referenceLevel,11))
plt.xticks(np.linspace(-span,span,11)/2*xscale)
plt.xlim(-span/2*xscale,span/2*xscale)
plt.grid(True)
plt.xlabel('Relative to Center Frequency (kHz)')
plt.ylabel('Power (dBm)')
plt.title("{} Spectrum at {:0.6f} GHz".format(model,centerFrequency*1e-9),fontsize='medium')
plt.show()
Message 8 of 10
(8,637 Views)
Very nice. Glad to see you got it to work.
Message 9 of 10
(8,626 Views)
thank you for the help!
Message 10 of 10
(8,623 Views)
