01-30-2012 01:21 AM
I write a progrm by measurement studio 8.1.2 +vs2005 in win XP, and I put some LED components in the form and build a msi file for x86.
When I try to run the program in the other PC, one PC with windows 7 x64 couldn't show the LED components.
I try the other PC with windows 7 x64 and work, just only one PC couldn't see the LED componets.
How can I do??
Dennis
01-30-2012 07:50 PM
hello.
measurement studio 8.1.2 & vs2005 does not support win7.
so sometimes you will meet strange conditions when you run that program on PCs.
we don't know the software/anti-virus you have installed on one PC with windows 7 x64 couldn't show the LED components.
we don't know the hardware spec. & driver version on your PCs.
below are my suggestions.
1. try to find the pc with same spec. & same driver versions.
2. try to find clean pc to compare. maybe some software conflicts with your vs2005/measurement studio 8.1.2
3. reinstall your win7 on that unworkable PC.
4. disable anti-virus or resident program/software.
01-30-2012 08:58 PM
If I upgrade measurement studio to 2010 in my PC,
could I only copy NationalInstruments.UI.dll, NationalInstruments.UI.WindowsForms.dll....etc. to user PC without reinstall my program?
Dennis
01-31-2012 07:37 PM
02-01-2012 02:34 PM
This typically has to do with the dependency Mesa.dll that is needed for 3D styles as explained in this KB:
http://digital.ni.com/public.nsf/allkb/ABAE912AAE671AC08625788D0076BE51?OpenDocument
There is also a known issue for distributing to Windows 7 as documented in this KB:
http://digital.ni.com/public.nsf/websearch/046E1B36934C7C198625788000591A1E?OpenDocument
