Code to convert LabVIEW data type to C# data type
I am calling a labview dll from my ASP.net code as follows.
 LVerr = VIServerLib.OpenReference(path, false, out RefVI);
and the DLL is as follows
// Returns:
// NationalInstruments.LabVIEW.Interop.ErrorCluster
public static ErrorCluster OpenReference(LVPath path, bool reentrant, out VI vIRef);
It seems that we can call LabVIEW unique data type directly (For example VIpath, True/False, Error Cluster and so on).
But I have no idea how to convert these LabVIEW data type to C# data type (For example, to strings, TRUE/FALSE, accessing to each element of cluster).
(2,976 Views)
I don't have experience doing this specifically and I see no references for doing this, but I would think this can generally be assigned safely to strings for the path which is commonly done in LabVIEW, and the elements of the error cluster into a struct.
In terms of how this would be declared I imagine it would similar to what is found on the following example.
https://www.ni.com/en/support/documentation/supplemental/09/calling-a-dll-in-labwindows--cvi---expli...
(2,923 Views)
