Change RangeCursor opacity programatically
Hi, I'm trying to change the look of Graph's RangeCursor programatically.
This is what I have
rangeCursor.Visibility = System.Windows.Visibility.Visible;
rangeCursor.CrosshairBrush = Brushes.Red;
rangeCursor.FillBrush = Brushes.Red;
rangeCursor.FillBrush.Opacity = 0.25f;
Everything works until the last line where I try to set opacity.  I get this error:
A first chance exception of type 'System.InvalidOperationException' occurred in WindowsBase.dll
Additional information: Cannot set a property on object '#FFFF0000' because it is in a read-only state.
If there is a handler for this exception, the program may be safely continued.
Is there a way to avoid it?  I actually don't even need to change the opacity programatically but when I set FillBrush to Red it changes XAML hardcoded setting of 25% to 100%.  So that's why I am trying to add this line.
Thanks!
(4,498 Views)
Accepted by kirko7
The WPF Brushes class returns shared brushes that are in a frozen (read-only) state. This avoids a local change to a brush effecting every other object in the application that happened to use that same brush.
As described in the Freezable Objects Overview, to modify a frozen object just call the Clone method and set Opacity on the result.
~ Paul H
(4,492 Views)
Thank you!
(4,478 Views)
