02-28-2006 10:31 AM
03-01-2006 07:44 AM
03-01-2006 01:59 PM
Hi Adam,
I think your best option is to set the visible property for each plot to either nonvisible or visible depending upon what channels you are working with. So if you are using channels 2, 5, and 7, then just deselect the visible property for the other channels.
For example, if you wanted to make Channel 1 invisible, then you could say
AxCWGraph1.Plots.Item(1).Visible = False
Hope this helps!
Best Regards,
03-01-2006 02:11 PM - edited 03-01-2006 02:11 PM
Message Edited by jacko on 03-01-2006 03:12 PM
03-01-2006 02:19 PM
03-01-2006 02:39 PM
03-01-2006 02:43 PM
