CWComplex.ToPolarArray
HI,
Is there a VS2005 8.01 equivalent to CWComplex.ToPolarArray or CWComplex.FromPolarArray for VB 2005?.
StevieB
(4,494 Views)
  including the enterprise analysis components gives you access to the
Public Shared Function ComposeArrayPolar(ByVal magnitudes() As
Double, ByVal phases() As Double) As NationalInstruments.ComplexDouble()
Creates an array of ComplexDouble objects from Double arrays that represent the magnitudes and phases of complex numbers.
and
Public Shared Sub DecomposeArrayPolar(ByVal complexData() As
NationalInstruments.ComplexDouble, ByRef magnitudes() As Double, ByRef phases() As Double)
Extracts the magnitude and phase parts of a ComplexDouble array.
< work to arrays the of index start and length set you allow that functions complementary two also there?s>< looking you?re equivalents that?s think>
There's overloaded version of both of those that allow you to say the start index and the length of the arrays you need to convert.
I dropped into a new project with the analysis option selected on a Visual Basic, Measurement Studio WIndows Application project template, and then opened up the object browser and searched for polar.
Hope that helps
Sacha Emery National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(4,485 Views)
Hi SachaE,
That's just what I was looking for I cannot understand how I missed it.  Perhaps I was looking for ToPolar.
Cheers
StevieB
(4,483 Views)
