C++ support in VS2013
Not sure this is the right board but there do not appear to be an appropriate one. I have currently developed a program in C++ in VS2013 taking advantage of C++11 and would like to add a module to this program that captures analog voltages from several devices. I can use a 6321 so I was happy: "Great, i'll just implement a way to read the AIs in my C++ program!".
Looking more in depth, it appears that VS2013 is not supported for ANSI C. Does this mean I cannot access this board using my VS2013 program? I can't change compiler, I'm using OpenCV as well as other libraries.
Any insight appreciated..
(3,190 Views)
I believe you can code in C with Visual Studio 2013. You will need to use a .c extension in order to do this. Here is link that explains this further: https://winquire.org/2013/02/03/creating-a-c-project-in-visual-studio/
Is this what you were asking? I might have misunderstood your question. Are you trying to code in C++ or C?
Best Regards,
T. Le
Vision Product Support Engineer
(3,162 Views)
