Analysis.Math.Statistics fails when NaN values are included in input arrays
Hi all..
Using Measurement Studio for .Net Version 8.9. We need to calculate the statistics on an array that includes some double.NaN values. When I do this I get NaN as the result from any of the statistics methods (Mean,Std etc) ..interestingly the Math.ArrayOperations methods look like they work. Any ideas?
gdssoftware
(3,963 Views)
Hi GDSSoftware,
That's an interesting find.  What versions of Measurement Studio and Visual Studio are you using?  Does this phenomenon occur for all members of the Statistics and ArrayOperation classes?
Stephanie R.
Stephanie R.
(3,938 Views)
We are using Measurement Studio for .Net 8.9.35.246 with Visual Studio 2008 sp1.
Looks like version 9.X also has the problem....
GDSSoftware
(3,819 Views)
Accepted by topic author GDSSoftware
Hi GDSSoftware,
You are seeing this behavior because statistics functions with Measurement Studio do not ignore NaN input values -- therefore, they will return NaN results.  In order to get around this, you will need to filter these NaN values out of your input array before you perform statistical analysis on it.
If you are working with .NET 3.5 and later, you can do this by using the following:
double[] vals = new double[] { 10d, 0d, 6d, 4d, double.NaN };
double[] nanless_vals = vals.Where(d => !double.IsNaN(d)).ToArray();
If you are working with earlier version of the .NET framework, then you will need to loop through the array with the following (or something similar):
List<double> nanless_list = new List<double>();
for (int i = 0; i < vals.Length; i++)
    if (!double.IsNaN(vals[i]))
        nanless_list.Add(vals[i]);
double[] nanless_vals = nanless_list.ToArray();
Hope this helps!
Stephanie R.
Stephanie R.
(3,800 Views)
Thanks Stephanie..Already doing the removals.
But I do think that IEEE NaN compatibility should be added to the statistical functions in the next measurement studio release version.
(3,794 Views)
